I am using my GL-AR750S-EXT Slate travel router. As this will be a sub router to a main router, how to I increase the upload speed? The upload speeds are significanlty lower going through the GL-AR750S-EXT Slate than directly through the main router. Everything is wired NOT wifi.
I have attached my home streaming network. All switches re unmanaged - dumb switches. GL.Net serves up IP Addresses on subnet 192.168.8.1. The Bell modem is now Starlink.
First test was with this setup. Download: 30mbps Upload: 1.9mbps
Second test was plugging the laptop (192.168.8.243) directly into the Netgear swtich. Download: 50 mbps Upload: 12 mbps
Third test was to plugging in the laptop (192.168.8.243) into the GL.Net router (bypassing the HP Switch - which is now another Netgear switch). Download: 30 mbps Upload:: 1.9 mbps
So needless to say, I can not stream with 1.9 mbps upload. I bought the GL.Net Slate for the ease of putting in a live streaming box so I can plug into it and have my own subnet to live stream from.
