How to login GL-X3000 on 192.168.8.1/rpc using php?
how to login http://192.168.8.1/rpc using php code?
can you please provide php login code?
Thank you,
Got it.
function get_hash($password, $salt, $alg, $nonce): false|string
    $unix_hash = '';
    switch($alg) {
        case 1:
            if (CRYPT_MD5 == 1) {
                // 12 character salt starting with $1$
                $unix_hash = crypt($password, '$1$' . $salt . '$');
            } else {
                die('MD5 not supported.');
            break;
            case 5:
                if(CRYPT_SHA256 == 1) {
                    // 16 character salt starting with $5$. The default number of rounds is 5000.
                    $unix_hash = 'CRYPT_SHA256: '.crypt($password, '$5$rounds=5000$' . $salt . '$');
                else {
                    die('CRYPT_SHA256 not supported.');
                break;
            case 6:
                if(CRYPT_SHA512 == 1) {
                    // 16 character salt starting with $6$. The default number of rounds is 5000.
                    $unix_hash = 'CRYPT_SHA512: '.crypt($password, '$6$rounds=5000$' . $salt . '$');
                else {
                    die('CRYPT_SHA512 not supported.');
                break;
    return md5('root:' . $unix_hash . ':' . $nonce);
I would prefer SSH for access, btw.
ok, thank you brother....
