How to make openclash software of openwrt
link: GitHub - vernesong/OpenClash: A Clash Client For OpenWrt
make && sudo make ipk is not successful!
my router is gl-mt1300.
please download the openwrt sdk from gl-inet/sdk and build it according to readme.
If you need to build the whole firmware, follow the instructions from coolsnowwolf/lede should be okay.
BTW, search google before you ask.
if you are use the same mips_24kc arch, you could use mine repo.
https://openwrt.kmahyyg.xyz/bin/packages/mips_24kc/base/luci-app-openclash_0.42.02-beta_all.ipk
