I would clarify that the file for the adguard home release from github? Is it the file is same as Flint of adguardhome_linux_armv7.tar.gz to download from release github for mutually upgrade on Slate AX?
Thanks!
Thanks!
Yes that’s the one, if you get the the setup wizard page which ask for DNS port let me know what you did cause I got stuck there.
Noted with thanks. Btw, i have successfully upgrade the adguard home to the latest version to 107.8
Did you not have to go through a setup wizard?
Nope. I used winscp to overwrite the file.
