How to minimize bandwidth usage
I am working on a macbook located on the other side of the planet, latency measured with ping is near 300ms. It is attached to a GL-RM1 and everything works fine so far. Since I often connect from weak and unstable wifis, and I cannot do anything about the latency, what are the recommendations to reduce bandwidth as much as possible? If the video of the screen looks like a potato is ok, the faster the better. My current settings:
  • Mode smart
  • Transfer WebRTC
  • Edid 1920x1200 60Hz (I chose this resolution because of its ratio 16:10 that fits well in my client laptop when fullscreen)
  • View Adaptive
try “WEBRTC FEC”
With WebRTC FEC the video stream seems smoother, thank you!
