I need to open port 44158 for my hotspot device, how can I do that?
Should be in Firewall settings:
You mean on 4G devices right? Carrier may not give you a public IP so opening port may do nothing.
You can either ask for a public IP (generaly with specific data plan, sim card and apn) or use vpn, then open the port from the vpn interface
Thanks, Will double check public IP - with VPN, how do I open port from VPN interface?
