On my routers config panel (GL-AR300M-730) it says that port 83 is not open. How / where can I do that, and is it needed to run OpenVPN?
Thanks
Thanks
with WAN access enabled I still get “port 83 not opened”, I also port forwarding port 83 in firewall.
any advise?, no main router…I am tethered GL-AR300M to a cell phone.
If you use smartphone tethering, you’d likely not be able to do remote access because carriers has a strong firewall.
