How to remove bloatware without native openwrt? (Opal device, so no support)
I want to remove following:
DDNS
Cloud control
Localisation (have only English)
Why I need to do this?
I need free up my space to make Adblock plugin work. Everything fine, just need free space.
No way to use Extroot, because no SD card slot, using USB as port for modem. No, I don’t want to buy USB splitter.
admon
May 26, 2024, 1:55pm
2
Those things won't make up enough space, so you will be happy with.
Basically they are only a bunch of scripts and small binaries.
I need to free up approximately 2,5 MB. Won’t this help?
admon
May 26, 2024, 2:02pm
4
Why do you need additional space anyway?
I just booted my Opal up and it shows 86.4M of free space. That should be enough for any Adblocker.
Wha?? I have only 8 free. Maybe it is because of Samba server? I can’t get rid of it, as I am using it from time to time to backup photos
admon
May 26, 2024, 2:07pm
6
Yup, Samba is too big. You need to decide if you want to run samba or adblocker.
So removing packages will not even free up 2,5 MB?
admon
May 26, 2024, 2:10pm
8
Not sure but they are mostly all small, nothing special.
Since you need additional space for the blocklists to be computed ... I highly doubt it's possible.
gl-cloud is for example only 25kb...
The firmware is on a read-only format. You cannot remove packages to save spaces.
When you remove one package, they are marked as removed but still occupy the spaces.
There is some scripts from here (example ) that modifies even firmware.
Or in my case it will not change anything?
@alzhao whats your recommendation then?
alzhao
May 28, 2024, 10:50am
11
What is your router model?
admon
May 28, 2024, 11:34am
13
But those scripts only add data, they don't delete anything.
The main file system is only some overlay above the original firmware files. So you can change stuff like replacing - but not by deleting. Deletion will just delete the link to the original file, not the file itself. Didn't thought about it, tbh, but @alzhao is right.
See:
root@Bilderrobbe:~# df -h
Filesystem Size Used Available Use% Mounted on
/dev/mtdblock14 45.8M 45.8M 0 100% /rom
tmpfs 192.7M 2.4M 190.3M 1% /tmp
/dev/ubi0_3 48.6M 2.5M 43.6M 5% /overlay
overlayfs:/overlay 48.6M 2.5M 43.6M 5% /
tmpfs 512.0K 0 512.0K 0% /dev
/dev/mtdblock13 4.0M 4.0M 0 100% /lib/firmware/IPQ5018/WIFI_FW
root@Bilderrobbe:~# rm /usr/sbin/tailscale*
root@Bilderrobbe:~#
Even after deletion of all tailscale binaries (which are huge) nothing changes.
