SIM went in (thankfully the correct way around) and works correctly, as I’m able to get a signal and can send/receive data.
But how do I get the SIM out again. There’s normally a spring-loaded catch that pushes it out when you need to remove it, but that doesn’t appear to be the case here.
Hopefully I’m not going to have to change it, but you never know.
