Is there any info on how to replace the SSL cert? I tried to replace the one in /etc/kvmd/nginx/ssl/ however it seems a new one was regenerated after a reboot, deleting my changes.
@minmie Can a long-term and effective approach be provided?
In version 1.4.0, we will change the certificate storage location to /etc/kvmd/user/ssl.And wouldn't regenerated again
Tried this today and after a reboot it did not replace the certs I put in /etc/kvmd/user/ssl.
Thanks, now can properly set this up using a reverse proxy with my SSCA.
could there be a direct integration with tailscale certs? obviously known to add to the public ledger, so it’d be an optional thing, but would be a nice fix for this too.
