How to restrict Wireguard VPN to WAN only on Brume2
HI
can anyone help me setting my firewall & zones the right way
Goal: i want to use my home as internet break out wenn i am travelling - but dont want to expose any ressources on my LAN.
Situation:
brume2 sits behind my router (which acts as DHCP Server and my internetprovider does not allow me to set any firewall rules or VLANs)
Brume acts as a Router, is connected via WAN Port to a LAN-Port on my main Router (=WAN exit)
via gl.inet webadmin i installed wireguard
in luci i turned off the brume2 dhcp
needed Help: how to isolate brume2 as wireguard ↔ wan only vpn
thanks in advance
thomas
I may not be understanding your scenario. Are you using WireGuard Server or WireGuard Client?
Are you wanting to use your home network as a forwarding node to access the Internet when you travel?
hi - thanks for asking. i use wireguard server at home - i want to connect while travelling (using a wireguard client) to my homeserver - but only for using my (home) internet (ip and breakout). eg.: some internet content is geo blocked … so i can read my newspaper (orf.at) from abroad. important: i dont want to expose anything else from my (hom) lokal LAN when using the wireguard tunnel
my settings so far
I think your “mgserver_deny_LAN” rule is work for the goal. We try it.
Alternatively, you can use the following at Firewall Custom Rules:
iptables -t mangle -I PREROUTING -i ovpnserver -d 192.168.173.0/24 -j DROP
