Wanted to ask how I can possibly run a reverse proxy on my new GL inet Flint 3 router.
Goal is like to have applications like e.g. adguard home, and other places be accessible from like adguard.website.com instead of like 192.168.8.1:3000,
also wanted to ask how to get/add free SSL certificates for it too using like either cloudflared domains or let's encrypt etc ?
OFC i gotta do a dns rewrite on adguardhome of like adguard.website.com to 192.168.8.1 too i guess ?
Access the ADG setting page needs to through domain + port, since ADG listens to port 3000, have to include the port number anyway, but you have to login the GL GUI before access the ADG setting page.
That's going to require the use of a proper reverse proxy daemon. HAProxy should be in the default GL.iNet repos... if not it should be. You're going to probably need LuCI &/or ssh to set it up. It's going to be some amount of effort, I'm sure. Better make a backup of your current conf:
