How to set GL-AR300M16-ext as wifi client witch dhcp forwarding
Hello All…
I have a question about this device…
is it possible to set this device in client mode and that it will forward dhcp from connected network… so that any device i connect with lan cable gets the same gateway subnet and dns as the network this mini router is connected to…
Kind regards
In firmware 3.x, go to admin panel->network mode->extender
Hi and thank you for the quick response… I had figured it out. have updated the devices I am going to use… And all is working fine now.
also I have disabled broadcasting its own network since it is not needed…
Kind regards
