I have the new Slate AX router.
But it gets hot and I want to change the temperature when the fan is activated.
At the bottom of this thread that discusses various ways of changing that setting there is a comment from GL-inet staff saying that “temperature control is available in firmware 4.1” and therefore they locked the thread from further comments.
So can anyone tell me the new and correct way of setting the fan temperature? Do I copy some of the commands in that thread (which one?) or do something else now? I can’t find it in the UI so I think that means I have to use some commands.
Would love to get a definitive answer and idiots guide to fix this thanks.
P.S. I am using MacOS. So if I have to use those commands can I do it through Terminal?
