I've been looking for some info about how to use the "Customize Routing Rules", I'm using the v4.5.16 and I'm not able to find this feature, I've found that in x3 versions there was a section instead of Tor's section where we could crear VPN policies but there's not anymore.
There's any guide I can read to try to set up this feature?
Maybe I missunderstood what this feature does, I thought it was to choose which devices are supposed to use the VPN and which one don't and exclude some domains from using VPN.
Okey, it's solved, I just went to Advanced settings>Network>Routing>IPv4 Rules and redirected that device which is connected to lan to use the wan interface.
