How to setup Guest zone with only access to Skype
Hello. On GLinet GL-MT 300N V2 i tried to restrict guest zone to Skyp
But can not figure out how to do it properly
Just when i restrict the guest zone with guestzone -> wan input reject output reject forward reject the wifi can not connect i have self assigned address
Please help if appropriate
here is my config :
BusyBox v1.30.1 () built-in shell (ash)
  _______                     ________        __
 |       |.-----.-----.-----.|  |  |  |.----.|  |_
 |   -   ||  _  |  -__|     ||  |  |  ||   _||   _|
 |_______||   __|_____|__|__||________||__|  |____|
          |__| W I R E L E S S   F R E E D O M
 OpenWrt 19.07.8, r11364-ef56c85848
root@GL-MT300N-V2:~# cat /etc/config/firewall
config defaults
	option input 'ACCEPT'
	option output 'ACCEPT'
	option forward 'REJECT'
	option flow_offloading '1'
	option flow_offloading_hw '1'
	option synflood_protect '1'
config zone
	option name 'lan'
	list network 'lan'
	option forward 'ACCEPT'
config zone
	option name 'wan'
	option masq '1'
	option mtu_fix '1'
	option input 'DROP'
	option network 'wan wan6 wwan'
config forwarding
	option src 'lan'
	option dest 'wan'
config rule
	option src 'wan'
	option proto 'udp'
	option dest_port '68'
	option target 'ACCEPT'
	option family 'ipv4'
config rule
	option name 'Allow-Ping'
	option src 'wan'
	option proto 'icmp'
	option icmp_type 'echo-request'
config rule
	option name 'Allow-IGMP'
	option src 'wan'
	option proto 'igmp'
config rule
	option name 'Allow-DHCPv6'
	option src 'wan'
	option proto 'udp'
	option src_ip 'fc00::/6'
	option dest_ip 'fc00::/6'
	option dest_port '546'
	option family 'ipv6'
config rule
	option name 'Allow-MLD'
	option src 'wan'
	option proto 'icmp'
	option src_ip 'fe80::/10'
	list icmp_type '130/0'
	list icmp_type '131/0'
	list icmp_type '132/0'
	list icmp_type '143/0'
config rule
	option src 'wan'
	option proto 'icmp'
	list icmp_type 'echo-request'
	list icmp_type 'echo-reply'
	list icmp_type 'bad-header'
	option limit '1000/sec'
config rule
	option src 'wan'
	option dest '*'
	option proto 'icmp'
config rule
	option name 'Allow-IPSec-ESP'
	option src 'wan'
	option dest 'lan'
	option proto 'esp'
config rule
	option name 'Allow-ISAKMP'
	option src 'wan'
	option dest 'lan'
	option dest_port '500'
	option proto 'udp'
config include
	option reload '1'
config include 'glfw'
	option type 'script'
	option path '/usr/bin/glfw.sh'
	option reload '1'
config zone 'guestzone'
	option name 'guestzone'
	list network 'guest'
	option input 'REJECT'
	option output 'REJECT'
config rule 'sambasharewan'
	option src 'wan'
	option dest_port '137 138 139 445'
	option dest_proto 'tcpudp'
	option target 'DROP'
config rule 'sambasharelan'
	option src 'lan'
config include 'gls2s'
	option path '/var/etc/gls2s.include'
	option reload '1'
config include 'glqos'
	option path '/usr/sbin/glqos.sh'
	option reload '1'
config forwarding
	option dest 'wan'
	option src 'guestzone'
	option ipset 'listenabledip'
config rule
	option dest 'wan'
	list dest_ip '15.188.101.115'
	option name 'sshtovpnallow'
config rule
	option name 'skypeallow'
	option dest 'wan'
	list dest_ip '111.221.74.0/24'
	list dest_ip '111.221.77.0/24'
	list dest_ip '157.55.130.0/24'
	list dest_ip '157.55.235.0/24'
	list dest_ip '157.55.56.0/24'
	list dest_ip '157.56.52.0/24'
	list dest_ip '213.199.179.0/24'
	list dest_ip '64.4.23.0/24'
	list dest_ip '65.55.223.0/24'
	list dest_ip '63.245.217.0/24'
	list dest_ip '134.170.19.0/24'
	list dest_ip '157.56.53.0/24'
	list dest_ip '191.239.211.0/24'
	list dest_ip '191.235.188.0/24'
	list dest_ip '134.170.0.0/24'
	list dest_ip '157.56.114.0/24'
	list dest_ip '191.233.80.0/24'
	list dest_ip '104.41.213.0/24'
	list dest_ip '104.40.141.0/24'
	list dest_ip '104.47.139.0/24'
	list dest_ip '191.235.187.0/24'
	list dest_ip '23.102.24.0/24'
	list dest_ip '91.190.216.0/24'
	list dest_ip '137.116.195.0/24'
	list dest_ip '134.170.24.0/24'
	list dest_ip '157.56.108.0/24'
config ipset
	option name 'listenabledip'
	option match 'dest_net'
	option enabled '1'
	list entry '111.221.74.0/24'
	list entry '111.221.77.0/24'
	list entry '157.55.130.0/24'
	list entry '157.55.235.0/24'
	list entry '157.55.56.0/24'
	list entry '157.56.52.0/24'
	list entry '213.199.179.0/24'
	list entry '64.4.23.0/24'
	list entry '65.55.223.0/24'
	list entry '63.245.217.0/24'
	list entry '134.170.19.0/24'
	list entry '157.56.53.0/24'
	list entry '191.239.211.0/24'
	list entry '191.235.188.0/24'
	list entry '134.170.0.0/24'
	list entry '157.56.114.0/24'
	list entry '191.233.80.0/24'
	list entry '104.41.213.0/24'
	list entry '104.40.141.0/24'
	list entry '104.47.139.0/24'
	list entry '191.235.187.0/24'
	list entry '23.102.24.0/24'
	list entry '91.190.216.0/24'
	list entry '137.116.195.0/24'
	list entry '134.170.24.0/24'
	list entry '157.56.108.0/24'
