I would like to know how to share my internet conexion with the GL-AR150 (firmware installed nano wifi pineapple) in os windows.
I followed the instructions from the video “University Wifi Pineapple” but It´s not possible for me to do it, because the GL-AR150 is not recognised as a Usb internet adapter…
I tried several things, but I am not able to get it…
I installed nano wifi pineapple on AR150 and I would like to have internet on this. I have my own Internet connection and I would like to share internet with Ar150. I don´t know how to sorted out this.
First connect a cable from the WAN interface for AR150 to your router. I think nothing will happen.
Does wifi pineapple has a interface for network configuration? The old version has. I am not sure about the nano version.
Finally you can find a way to ssh to the router, and change network configuration, it is /etc/config/network, if you can get access to this file, post its contents.
I think definitly the solution is manage the router to get internet to the AR150. I was trying this weekend at my parent´s house and , but unfortunally I couldnt access to the router because I didnt know the password of the router, but the next weekend I think I will know the password and I will be able to share the internet conection to the AR150.
In the original NANO, there is a internet adapter USB and that get easier to share the internet connection to this adapter.
In the AR150 is not possible do this because there is not internet adapter.
