I want to disable remote access for Cloud Management, but how to “turn off the wifi coverage function in the goodcloud management web”?
Did you ever use WiFi statistics function in good cloud which is only for business users?
Or which model and firmware you are using? Need to change if it is a bug.
I have Convexa-B (GL-B1300) and am running version 3.104 of the firmware.
I was given early access to goodcloud.xyz and so possibly used the WiFi statistics function.
Is there a quick way for me to turn off the function on the router?
My device identifier is “hp1d28b” by the way (in the America region)
login https://us.goodcloud.xyz, find the “Group List” on the left side, toggle off the “Analytics” of the group
