bluej
April 3, 2023, 5:29pm
I have the GL-AR300M16.
There are 3 applications which are not installed by default and needs to be manually installed:
File Sharing
Multimedia Sharing
Luci
However the unit doesn’t have enough flash space to host all of those 3 applications. I need to uninstall file sharing to have enough space for Luci.
I assume I can do so in Application/Plugin. But what plugin name?
So again, I would like to know how to uninstall the following application once it is installed on the router.
File Sharing
Multimedia Sharing
Luci
Thank you!
To uninstall in router ssh terminal:
File Sharing:
opkg remove --force-removal-of-dependent-package gl-files-browser
opkg remove --force-removal-of-dependent-package samba36-server
Multimedia Sharing
opkg remove --force-removal-of-dependent-package libbz2
opkg remove --force-removal-of-dependent-package libexif
opkg remove --force-removal-of-dependent-package libffmpeg-mini
opkg remove --force-removal-of-dependent-package libflac
opkg remove --force-removal-of-dependent-package libid3tag
opkg remove --force-removal-of-dependent-package libjpeg
opkg remove --force-removal-of-dependent-package libogg
opkg remove --force-removal-of-dependent-package libvorbis
opkg remove --force-removal-of-dependent-package minidlna
Luci
opkg remove --force-removal-of-dependent-package cgi-io
opkg remove --force-removal-of-dependent-package libiwinfo-lua
opkg remove --force-removal-of-dependent-package liblua5.1.5
opkg remove --force-removal-of-dependent-package liblucihttp-lua
opkg remove --force-removal-of-dependent-package liblucihttp0
opkg remove --force-removal-of-dependent-package libubus-lua
opkg remove --force-removal-of-dependent-package lua
opkg remove --force-removal-of-dependent-package luci
opkg remove --force-removal-of-dependent-package luci-app-firewall
opkg remove --force-removal-of-dependent-package luci-app-opkg
opkg remove --force-removal-of-dependent-package luci-base
opkg remove --force-removal-of-dependent-package luci-lib-ip
opkg remove --force-removal-of-dependent-package luci-lib-json
opkg remove --force-removal-of-dependent-package luci-lib-jsonc
opkg remove --force-removal-of-dependent-package luci-lib-nixio
opkg remove --force-removal-of-dependent-package luci-mod-admin-full
opkg remove --force-removal-of-dependent-package luci-mod-network
opkg remove --force-removal-of-dependent-package luci-mod-rpc
opkg remove --force-removal-of-dependent-package luci-mod-status
opkg remove --force-removal-of-dependent-package luci-mod-system
opkg remove --force-removal-of-dependent-package luci-proto-3g
opkg remove --force-removal-of-dependent-package luci-proto-ipv6
opkg remove --force-removal-of-dependent-package luci-proto-ncm
opkg remove --force-removal-of-dependent-package luci-proto-ppp
opkg remove --force-removal-of-dependent-package luci-proto-qmi
opkg remove --force-removal-of-dependent-package luci-proto-relay
opkg remove --force-removal-of-dependent-package luci-proto-wireguard
opkg remove --force-removal-of-dependent-package luci-theme-bootstrap
opkg remove --force-removal-of-dependent-package rpcd
opkg remove --force-removal-of-dependent-package rpcd-mod-file
opkg remove --force-removal-of-dependent-package rpcd-mod-iwinfo
opkg remove --force-removal-of-dependent-package rpcd-mod-luci
opkg remove --force-removal-of-dependent-package rpcd-mod-rrdns
opkg remove --force-removal-of-dependent-package uhttpd
