What is the correct procedure to upgrade AdGuard Home to v0.107.6 on my Flint?
Thanks
Thanks
I just did it and it works. Not sure if it can just be normal when upgrade openwrt.
Hi alzhao,
Thanks for your response. I have tried several times but I keep getting a failure.
I am using code version 3.213
Any ideas ?
Thanks
Hi alzhao,
Yes that worked.
I upgraded to 3.214 and I was now able to upgrade adguard from the GUI.
Thank you for your help
