Hi, how do you use AmneziaWG obfuscation on the MT3000?
It is early beta - it is on you to figure that out I think. Do some googling and see what you can find.
If you only have one MT3000, you need to use a third-party VPN services (like AmneziaWG) provided obfuscation profile.
You can manually export profiles with obfuscation protocols in AmneziaWG and upload them to your router manually. -
If you have 2 MT3000s, you can put one MT3000 at home or office as a VPN server, and the other one is carried on travel or business trips and as a VPN client. After enabling obfuscation parameters, your VPN connection will be stronger and more stable.
Currently in the small-scale testing stage, there is no arrangement to write a docs/guide.
We would like to verify whether it is available before deciding whether this function is integrated into the standard firmware.
