I did a quick search to pick an fs with low wear. I definitely am not an expert on it. It would be annoying to lose data but it’s just acting as a media server in my RV so the overall risk is low. It’s not the ONLY copy of Endgame
Still, I’m happy to hear any recommendations from those who have thought about it longer than I have. Ext4 with journal disabled maybe?
Personally, I wouldn’t disable journalling as routers tend to have the power pulled on them, and it doesn’t seem like an application that demands the absolute, top write speeds possible.
f2fs is mostly for onboard NAND/eMMC for Android - and not really recommended for flash devices that can be easily removed like MicroSD and USB sticks.
As @jeffsf suggests - ext4 is robust for external devices and mount points, and journaling there is a plus when considering the use case - RV, where power might be unpredictable.
x750 isn’t going to really push any USB storage device really hard in any event.
