How to use the function of adblock in GL-MT1300
after installation of adblock,how to use it?
I have set it enable in high function,but no effect.
hope to get method of application.thans
  1. Install LuCI.
  2. Install LuCI-adblock
  3. There will be a new Services tab in LuCI. Under it will be an adblock page.
  4. On that page, enable adblock. Tab over to the blocklists page, select the lists you want.
That should be it. I’ve done it on both the stable .200 firmware and the .201 beta.
thanks first,but no effect before video
What do you mean before video? This will certainly not block youtube ads.
I thought it will block youtube ads
