I read many of the threads here and now I see that old plan to stop supporting Tor on 3.x is only old plan because 3.1 have Tor. Correct?
Okay so I install 3.1 firmwares. I see package “gl-tor” in softwares. But I do not see how I should use this. If I click little button on side of router, I have no changes. I have access to router at same address in web gui, and traffic does not use Tor.
What is correct method for using Tor on 3.1?
What is method to make button do triggering for Tor on/off?
If you do have this web page in web admin,
then check enabled, then hit the apply button.
You may have to wait up to 2 minutes for tor to connect. A status of the connection will appear below ‘exit node country’ with bootstrap requiring to get to 100%
