I want to load balance between wan port and wifi client and access them via wireless access point.
However i cant create a vlan because there is no switch option under network. How can i make this work? 2.27
You don’t need a vlan I think.
Just go to luci->network->load balancing and have a try.
I try but when i command mwan3 start the interfaces go online and can ping but the balancing doesnt work and i get
root@GL-AR300M:~# mwan3 start
uci: Entry not found
grep: : No such file or directory
cat: can’t open ‘/var/run/ovpn_client.pid’: No such file or directory
grep: /proc/device-tree/model: No such file or directory
sh: you need to specify whom to kill
old process id exist
time_since_update = hours
root@GL-AR300M:~# old process id exist
