I want to configure a wireguard vpn connection with udp over tcp or stealth protocol from protonVPN on AX1800 Flint because in Egypt country, ISP block UDP port (openvpn with tcp is block too…).
Do you have any experience to build this ?
I saw on internet and many forum but they used udpraw or udptunnel to create tunnel from endpoint A to endpoint B. Here, i want to use the vpn provider, not my VPN server.
Hello fellow Egyptian,
The only way to do this is build wireguard-go from protonvpn github here: ProtonVPN/wireguard-go (github.com) and compile it for arm with golang compiler, then transfer it with SCP to the router, then write a custom script that creates the VPN connection. And then the Wireguard GUI in Flint router won’t work but the vpn will work.
The script will manually make the wireguard tunnel and set the routing table rules. But I’m not sure how to activate the “stealth” mode in this wireguard-go. Most probably some new wireguard configuration rules.
