Hello, everyone,
As is well known, you can only use the VPN server / client on the MV1000 if
when the MV1000 is in router mode.
The MV1000 (FW 3.203) is currently connected to the FRITZ! Box as a cascaded router via WAN on the LAN.
Is it still possible to use the MV1000 as an IP client
to operate behind another router and that you can use the VPN server / client + AGH?
The router on the DSL Internet connection is an FBRITZ! Box 7590. The FRITZ! Box’s DHCP is for the IP range
192.168.178.20 to 200 switched on.
I would like to continue to use the LAN connections on the FRITZ! Box for other AVM-FRTZ! Products (wlan repeaters, power liners, IP-telephones).
I could now switch off the DCHP of the FRITZ! Box and tell the FRITZ! Box that the DHCP for the home network is the IP of the VM1000,
but which is in the same IP address range as the FRITZ! Box.
How could I persuade the VM1000 to be DHCP (e.g. via AGH) for my home network devices and at the same time VPN client / server + AGH,
without having to register / connect all LAN / WLAN devices directly to the MV1000?
Thank you in advance for the swarm knowledge.
With best regards from Germany
