The GL-MT300N router only seems to support http. How can I secure the web UI with https or luci-ssl?
Thanks
Thanks
Look for and install the luci-ssl package
https://wiki.openwrt.org/doc/howto/luci.essentials?s[]=luci&s[]=ssl
hi~,
i got the luci-ssl installed (see picture),
but I still cannot connect using https://192.168.8.1 in my brave browser.
mine is brumeW, 3.104.
thank you.
The SSH admin access is always SSL-encrypted by default)
opkg update
opkg install luci-ssl
/etc/init.d/uhttpd restart
you can now access the web admin GUI by using http://192.168.1.1
Still FAIL after I tried the above from openwrt:
pls help.
using HTTP is no good, all the other devices on my LAN can tap me.
thanks
oh after I installed luci-openssl it removed me from my GL inet UI,
I better stop playing with this.
I have to reset my router.
hope later HTTPS could be used.
thanks
