I’m using a Beryl AX with firmware v4.4.6. In older versions using lighttpd, I followed the instructions in this post to redirect all http requests to https. But now the webserver is nginx, and I’d like to know if it’s possible to do the same thing.
On the router, in the file /etc/config/oui-httpd, I changed option redirect_https to '1', and that works for the basic GUI, but doesn’t apply to the LuCI web interface. Is there also a simple change I can make for https redirection with both interfaces?
Thanks for the reply. I followed those instructions, and the variable uhttpd.main.redirect_https maintains its value even after a reboot. But it doesn’t seem to have any effect. Redirection does not occur, and I can still log in to LuCI over http.
