Huawei E8372h-608
Confirming Huawei E8372h-608 works out of the box in Tethering mode on Flint2 GL-MT6000 and Beryl AX3000. Not sure why its called tethered mode as it creates eth2 interface on the router rather than connect via the dongle's wifi.
Modem mode or tethering mode is based on the operating mode of USB dongle.
If it supports to switch to modem mode, GL router will recognize it as modem.
Because consumers always think about plug-and-play when buying and using the USB dongles, so dongles will automatically dial and connect base station, instead of the router or PC to control them. That is reason why the most USB dongles on the market are tethering mode, tethering mode means that after the USB dongle is plugged in, it will automatically dial and then allocate a LAN subnet IP to the device.
