When I connect this with Windows 10/11, it brings a Windows built-in interface, where I can put APN etc so connect. The interface is quite like wifi interface.
But when I use this modem with GL-AX1800 router, It seems like the router do not recognise this as a device. Can you please suggest how I can make use of this modem with my router?
This USB dongle does not support, please refer to this supported list:
It needs to configure the APN in its interface before use it. Means that driver for this device probably special (Not pure Modem/Module devices), required to debug and develop if connect to the OpenWRT OS to work.
Thanks a lot for your prompt reply. If I'm not wrong, this modem is MBIM supported modem and libmbim is also available. I was wondering how to make these work.
Mate, I am not too technical person but I can understand some things. If you check this post, the person made this modem work on raspberry pi using libmbim-utils.
Then I found libmbim is available for OpenWRT. Now I need someone to help me how to configure what and test if this is working.
Also came across this post, seems like rNDIS also works. Can you please provide a simplified guideline?
Please note, I would not use this device as my primary connection, this device will take over when internet is down, so I do not want to make any changes, where this will be my primary internet connection source.
