On my Comet KVM setup, mouse and keyboard works, but screen shows just my remote PC's wallpaper. I am still could not figured out what causing the issue, but any help or advise would be appreciated.
Here is remote PC spec.
HW: Intel NUC 8
OS: Windows 11 Pro
By the way, I have tested different PC (Dell Inspiron 7300) as remote machine and there was no issue. So, I assume this Comet KVM itself works very well.
@bruce Thank you very much for your reply. I checked the Multiple Displays setting, but it is already "Extend these displays" selected on both display #1 (My main monitor) and #2 (GLKVM).
Even I re-selected "Extend these displays", nothng change...
Hello @robotluo, thank you very much for your reply. I am able to see my remote computer's screen with "Duplicate these displays" option. I'd like to try various things, but next I would like to try using tailscale.
