I can remote access through myddns.glddns.com with port 80 (http) but not port 443 (https)
Model No.: GL-MT300N-V2
Software version: 3.102
I have enable both the http and https access in the ddns part.
I have also set the port forward on the previous router for both port 80 and 443,
but I encounter a " ERR_CONNECTION_TIMED_OUT" by using chrome when access to https://myddns.glddns.com, but have no problem when access to http://myddns.glddns.com
I hope I can only enable https access for a better security.
can you try a different port on your main router’s port forward settings?
e.g. 444 forward to 443, then use
https://myddns.glddns.com:444
Just check if your operator blocks this port
The 443 is used by other service and it become ok now after changing the port forward setting for “443 to 443” to “1443 to 443”
