I can't find wifi SSID
I am using ar300m-ext router. Everything worked fine, I decided to update the firmware, downloaded it from the official site. Now I can’t find wifi ssid. I also cannot connect to the router panel (192.168.8.1). The reset button doesn’t help. What can be done ?
Which firmware did you download?
Can you use uboot to reinstall the firmware?
Firmware can be download from GL.iNet download center
uboot guide Debrick via Uboot - GL.iNet Docs
