PROS:
- Less devices
- Less clutter
- Rack mounting
CONS:
- Only one active connection. I used to have all 4 connections opened in different tabs, now I have to switch ports which takes a while and have to wait until the device wakes up, see next.
- Despite enabling mouse jiggler, it only affects the active port. All the other ports locked themselves or go to sleep
This is neither good or bad. It depends on your needs, but for me, it’s very important to have all the other devices opened so I can quickly glance what’s going on. Having to switch ports is not ideal for my purpose but would be good for others.
I wish the GL-RM4PE could have all the connections active so when I switch ports it would instantly show the screen and avoid the device to lock or go to sleep.
Is this something that could/would be implemented in the future?
Thanks
