I want to use the guest network for IoT - is it possible to use the gli-inet firmware's firewall rules UI to achieve this?
I noticed that the built-in firewall UI lets users specify guest and LAN zones... Is it possible to then to create a simple rule using the UI to allow multicast DNS and other necessary protocols between the guest network and LAN?
I would like to avoid luci and iptables if possible.
Could someone please give a working example in what to put in the built-in firewall's options to open up the following ports between the gust network and LAN:
mDNS
iptables -A INPUT -p udp -m multiport --dports 5353 -j ACCEPT
Homekit Protocol
iptables -A INPUT -p tcp -m multiport --dports 51827 -j ACCEPT
Home Assistant interface
iptables -A INPUT -p tcp -m multiport --dports 8123 -j ACCEPT
Thanks!
… For example - not sure what I should put for “internal IP” or “internal ports”.
In this example, I have the IP address of a device in the guestzone which seems like that should be wrong.
I was not able to put 192.168.8.* either.
Not really sure whether it should be LAN or Guestzone device IP.
Also… for the itnernal port, should I use the same or just pick any old random port?
Thanks
You can add you firewall rules in MORE SETTINGS-> Advanced->network->firewall
Hey thanks, I realise this. I just wondered if the rules I wanted to add could be done with the gl-inet firmware, and if so, what to put for ‘internal IP’ and ‘internal ports’.
Are you saying that my usecase is not possible then for the GL-inet GUI?
Thanks again.
