- Everything goes through the VPN.
- Some Devices shouldn’t go through the VPN.
- Some domains and IPs shouldn’t go through the VPN.
I currently have Beryl AX (GL-MT3000) on v4.1.3
I want to use both policies
There is currently no way to support both policy.
Will there be?
Or some other way to achieve this?
Use two different routers
Also, your bank doesn’t care about VPN use. Wait until Tor releases its planned VPN and then it will be an issue since it will use random exit nodes rather than secured VPN server IPs
Just an example
Mainly I want to use it for services like GeForce Now or shadow PC
There are no plans to develop this feature at the moment, such a configuration would be too complex to use.
