Currently, the GL.iNet web interface allows users to configure only one ZeroTier Network ID. This limits flexibility because users cannot connect their router to multiple independent ZeroTier virtual networks simultaneously through the standard web interface.
In real-world scenarios, users may need to connect to several ZeroTier networks to access different servers, remote offices, home networks, or other devices.
Proposed Solution:
Add support for managing multiple ZeroTier networks directly from the GL.iNet web interface.
Ideally, each network should have the following options:
Add and remove ZeroTier Network IDs.
Enable or disable each network independently.
Configure Allow Remote Access WAN and Allow Remote Access LAN separately for each network.
Display the Router Virtual IP assigned to each network.
Display individual connection status (Connected / Disconnected).
Allow multiple ZeroTier networks to operate simultaneously.
UI Design Proposal:
I have prepared a concept showing how the existing ZeroTier settings page could be redesigned to support multiple networks while maintaining the familiar GL.iNet design language.
The proposed interface includes separate configuration sections for each network and an Add Network button.
The goal is to keep the interface simple, intuitive, and consistent with the current GL.iNet user experience.
Question for the Development Team:
Are there any plans to introduce official support for multiple ZeroTier networks in future GL.iNet firmware releases?
As far as I understand, ZeroTier itself already supports joining multiple networks simultaneously. It would be extremely useful to have this functionality available directly through the GL.iNet web interface without requiring manual SSH configuration.
Thank you for considering this feature request. I believe it would be a valuable improvement for users managing multiple remote networks.
