I have been trying to get an I2C clock up and going on the gl-ar750 (the one in the white enclosure) using the i2c pins which are already populated on the device and they do not seem to work. I compiled a custom openwrt (from gl-inet github) and have the i2c-custom seems to be properly configured from what I can tell. However, whensing i2cdetect I do not see anything on the i2c bus. (i2cdetect -r -y 0)
I have a gl-ar750s (grey with external antenna) which I soldered a header on for the i2c and that works flawlessly, so I know the RTC I’m trying to use works.
I’m curious if anybody has gotten the i2c bus working on the gl-ar750 and if they have any suggestions.
