when working with openvpn I found when I get a
reserving recently used remote address: [AF_INET]31.171.152.137:443
response I always do a hard reboot and test again.
post your .conf file. do not include user auth info
I don’t have much experience working with cyberghost, but my friend runs it on windows 10, didnt have a problem with setting up. Can you post your config? I’ll ask him for advice.
Yes. Also, auth-user-pass requires a parameter of a file name containing the username and password which seems to be missing in both above configurations.
I’m wondering if they uploaded that config through the GL web UI and it inserted the option and when it asked for the username and password the user left the option blank and the resulting configuration file is broken
Now I am using bmxscott config file and it is working. Seems to me that Cyberghost has changed something since I tried this configuration before and it failed.
nopro404, you are right: I have to insert manually the username and password through the GL web UI when upload the config file.
