I don’t have a full blown linux machine, only a couple of PIs. The rest are Windows and Chromebook. One PI is running Kali.
Does anyone know if using a PI, if it is possible to build an image for an AR300M that includes base Gl firmware, a couple of WiFi adapter kmod files, a handfull of other programs, and of course my config file?
+1 virtualbox - imagebuilder is built for x86_64 it won’t work on arm. or get a vm on digital ocean or whatever, it will pull the imagebuilder repo and build it way faster than the time it will take you to setup vbox and an image and costs around 5 cents.
Thanks for the suggestions. I’ll check what the windows machine has under the hood. It’s old, runs vista, may not even be 64 bit. I just keep it around for Putty, WinSCP, and other tools. I am happy every time it still boots in under 10mins.
