There is a .txt file in imagebuilder firmware files folder (.txt above)
Does that mean the images produced should not be used? (was like that a month ago too when trying to build an image)
I know this file but can you give the exact path to check?
It’s showing in the /bin folder output (the place where the outputted .img or .bin file goes)
So, for example, in my case it was /gl_imagebuilder/bin/220320/mt300n-v2/Do not use until this file is removed.txt
Pls change the state from “develop” to “release”
You can omit this message actually.
