I am facing a unique issue with my GL-iNET Brume 2 gateway. The PPPoE authentication and internet connection only hold as long as my phone is connected to the gateway via a USB cable. The moment I disconnect the USB cable, the PPPoE authentication fails, and the internet connection drops instantly.
Here’s a simplified outline of the issue:
- Device: GL-iNET Brume 2
- Scenario: PPPoE authentication and internet connectivity are stable only while my phone is connected via USB to the gateway. No actual tethering is needed, just the physical connection of the USB cable.
- Problem: The instant the USB cable is disconnected, PPPoE authentication fails, and the internet connection is lost.
I have attempted rebooting the device, rechecking the PPPoE settings, and looking through the logs, but haven’t found a clue to resolve this. Has anyone come across a similar issue or have any insights on how to troubleshoot this? Your assistance would be highly appreciated.
Logs:
Mon Oct 2 12:57:07 2023 kern.info kernel: [ 1124.732144] usb 1-1: USB disconnect, device number 3
Mon Oct 2 12:57:07 2023 kern.info kernel: [ 1124.764075] ipheth 1-1:4.2: Apple iPhone USB Ethernet now disconnected
Mon Oct 2 12:57:07 2023 daemon.err usbmuxd[12479]: [12:57:07.274][3] Removed device 2 on location 0x10003
Mon Oct 2 12:57:15 2023 daemon.info pppd[28223]: No response to 5 echo-requests
Mon Oct 2 12:57:15 2023 daemon.notice pppd[28223]: Serial link appears to be disconnected.
Mon Oct 2 12:57:15 2023 daemon.info pppd[28223]: Connect time 15.9 minutes.
Mon Oct 2 12:57:15 2023 daemon.info pppd[28223]: Sent 11232891 bytes, received 13791884 bytes.
Mon Oct 2 12:57:15 2023 daemon.notice netifd: Network device 'pppoe-wan' link is down
Mon Oct 2 12:57:15 2023 daemon.info avahi-daemon[4036]: Interface pppoe-wan.IPv4 no longer relevant for mDNS.
Mon Oct 2 12:57:15 2023 daemon.info avahi-daemon[4036]: Leaving mDNS multicast group on interface pppoe-wan.IPv4 with address 136.110.26.153.
Mon Oct 2 12:57:15 2023 daemon.info avahi-daemon[4036]: Withdrawing address record for 136.110.26.153 on pppoe-wan.
Mon Oct 2 12:57:15 2023 daemon.notice netifd: Interface 'wan' has lost the connection
Mon Oct 2 12:57:16 2023 user.notice mwan3[15608]: Execute ifdown event on interface wan (unknown)
Mon Oct 2 12:57:16 2023 user.info mwan3track[28817]: Detect ifdown event on interface wan (pppoe-wan)
Mon Oct 2 12:57:16 2023 user.notice mwan3track[28817]: Interface wan (pppoe-wan) is offline
Mon Oct 2 12:57:16 2023 user.notice firewall: Reloading firewall due to ifdown of wan ()
Mon Oct 2 12:57:16 2023 authpriv.notice sudo: root : PWD=/ ; USER=root ; GROUP=nonevpn ; COMMAND=/usr/lib/ddns/dynamic_dns_updater.sh -- stop
Mon Oct 2 12:57:16 2023 user.notice ddns-scripts[29263]: glddns: PID '29263' terminated by 'SIGTERM' at 2023-10-02 12:57
Mon Oct 2 12:57:17 2023 authpriv.notice sudo: root : PWD=/ ; USER=root ; GROUP=nonevpn ; COMMAND=/usr/lib/ddns/dynamic_dns_updater.sh -- start
Mon Oct 2 12:57:18 2023 user.notice ddns-scripts[16184]: cloudflare_aschneider: PID '16184' started at 2023-10-02 12:57
Mon Oct 2 12:57:18 2023 user.notice ddns-scripts[16180]: glddns: PID '16180' started at 2023-10-02 12:57
Mon Oct 2 12:57:18 2023 user.warn ddns-scripts[16184]: cloudflare_aschneider: Service section disabled! - TERMINATE
Mon Oct 2 12:57:18 2023 user.warn ddns-scripts[16184]: cloudflare_aschneider: PID '16184' exit WITH ERROR '1' at 2023-10-02 12:57
Mon Oct 2 12:57:21 2023 daemon.notice pppd[28223]: Connection terminated.
Mon Oct 2 12:57:21 2023 daemon.info pppd[28223]: Sent PADT
Mon Oct 2 12:57:21 2023 daemon.notice pppd[28223]: Modem hangup
Mon Oct 2 12:57:21 2023 daemon.info pppd[28223]: Exit.
Mon Oct 2 12:57:21 2023 daemon.notice netifd: Interface 'wan' is now down
Mon Oct 2 12:57:21 2023 kern.info kernel: [ 1139.284894] mtk_soc_eth 15100000.ethernet eth0: Link is Down
Mon Oct 2 12:57:21 2023 daemon.info avahi-daemon[4036]: Interface eth0.IPv6 no longer relevant for mDNS.
Mon Oct 2 12:57:21 2023 daemon.info avahi-daemon[4036]: Leaving mDNS multicast group on interface eth0.IPv6 with address fe80::9383:c4ff:fe33:c57f.
Mon Oct 2 12:57:21 2023 daemon.info avahi-daemon[4036]: Withdrawing address record for fe80::9383:c4ff:fe33:c57f on eth0.
Mon Oct 2 12:57:21 2023 daemon.notice netifd: Interface 'wan' is disabled
Mon Oct 2 12:57:21 2023 kern.info kernel: [ 1139.296851] mtk_soc_eth 15100000.ethernet eth0: PHY [mdio-bus:05] driver [Maxlinear Ethernet GPY211C]
Mon Oct 2 12:57:21 2023 kern.info kernel: [ 1139.306115] mtk_soc_eth 15100000.ethernet eth0: configuring for phy/1000base-x link mode
Mon Oct 2 12:57:21 2023 daemon.notice netifd: Interface 'wan' is enabled
Mon Oct 2 12:57:21 2023 daemon.notice netifd: Interface 'wan' is setting up now
Mon Oct 2 12:57:21 2023 daemon.notice netifd: Network device 'eth0' link is down
Mon Oct 2 12:57:21 2023 daemon.notice netifd: Interface 'wan' has link connectivity loss
Mon Oct 2 12:57:21 2023 daemon.err insmod: module is already loaded - slhc
Mon Oct 2 12:57:21 2023 daemon.err insmod: module is already loaded - ppp_generic
Mon Oct 2 12:57:21 2023 daemon.err insmod: module is already loaded - pppox
Mon Oct 2 12:57:21 2023 daemon.err insmod: module is already loaded - pppoe
Mon Oct 2 12:57:21 2023 daemon.notice netifd: wan (16587): Command failed: Permission denied
Mon Oct 2 12:57:21 2023 kern.info kernel: [ 1139.473482] mtk_soc_eth 15100000.ethernet eth0: PHY [mdio-bus:05] driver [Maxlinear Ethernet GPY211C]
Mon Oct 2 12:57:21 2023 kern.info kernel: [ 1139.482747] mtk_soc_eth 15100000.ethernet eth0: configuring for phy/1000base-x link mode
Mon Oct 2 12:57:22 2023 user.notice mwan3[16672]: Execute ifdown event on interface wan (unknown)
Mon Oct 2 12:57:22 2023 user.info mwan3track[28817]: Detect ifdown event on interface wan (pppoe-wan)
Mon Oct 2 12:57:22 2023 user.notice mwan3track[28817]: Interface wan (pppoe-wan) is offline
Mon Oct 2 12:57:22 2023 user.notice firewall: Reloading firewall due to ifdown of wan ()
Mon Oct 2 12:57:22 2023 authpriv.notice sudo: root : PWD=/ ; USER=root ; GROUP=nonevpn ; COMMAND=/usr/lib/ddns/dynamic_dns_updater.sh -- stop
Mon Oct 2 12:57:24 2023 authpriv.notice sudo: root : PWD=/ ; USER=root ; GROUP=nonevpn ; COMMAND=/usr/lib/ddns/dynamic_dns_updater.sh -- start
Mon Oct 2 12:57:24 2023 user.notice ddns-scripts[17316]: glddns: PID '17316' started at 2023-10-02 12:57
Mon Oct 2 12:57:24 2023 user.notice ddns-scripts[17320]: cloudflare_aschneider: PID '17320' started at 2023-10-02 12:57
Mon Oct 2 12:57:24 2023 user.warn ddns-scripts[17320]: cloudflare_aschneider: Service section disabled! - TERMINATE
Mon Oct 2 12:57:24 2023 user.warn ddns-scripts[17320]: cloudflare_aschneider: PID '17320' exit WITH ERROR '1' at 2023-10-02 12:57
Mon Oct 2 12:57:28 2023 kern.info kernel: [ 1145.624534] mtk_soc_eth 15100000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
Mon Oct 2 12:57:28 2023 kern.info kernel: [ 1145.632822] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Mon Oct 2 12:57:28 2023 daemon.notice netifd: Network device 'eth0' link is up
Mon Oct 2 12:57:28 2023 daemon.notice netifd: Interface 'wan' has link connectivity
Mon Oct 2 12:57:28 2023 daemon.notice netifd: Interface 'wan' is setting up now
Mon Oct 2 12:57:28 2023 daemon.err insmod: module is already loaded - slhc
Mon Oct 2 12:57:28 2023 daemon.err insmod: module is already loaded - ppp_generic
Mon Oct 2 12:57:28 2023 daemon.err insmod: module is already loaded - pppox
Mon Oct 2 12:57:28 2023 daemon.err insmod: module is already loaded - pppoe
Mon Oct 2 12:57:28 2023 daemon.info pppd[17722]: Plugin rp-pppoe.so loaded.
Mon Oct 2 12:57:28 2023 daemon.info pppd[17722]: RP-PPPoE plugin version 3.8p compiled against pppd 2.4.8
Mon Oct 2 12:57:28 2023 daemon.notice pppd[17722]: pppd 2.4.8 started by root, uid 0
Mon Oct 2 12:57:28 2023 user.notice ddns-scripts[16180]: glddns: PID '16180' terminated by 'SIGTERM' at 2023-10-02 12:57
Internet (PPPE) working while UBS is connected to the phone:
The moment I disconnect the phone:
Thank you in advance!
