Inconsistent multi-wan/mwan3 configuration and behavior
Spitz GL-X750 running 4.3.25, while troubleshooting US Verizon LTE issues (which I'll post separately) I notice the GUI, process list, and possibly the config file for mwan3 are inconsistent.
In one case, with mwan3 set to ignore the LTE modem, it still monitors the modem (and may be contributing to my connection issues). In the current case, WAN ethernet is configured for mwan3, the LTE interface should be ignored, but both are being monitored.
oot@spitz:~# pgrep -laf mwan
24416 /bin/sh /usr/sbin/mwan3track wan eth0 online 100.79.201.41 1.1.1.1 8.8.8.8 208.67.222.222 208.67.220.220
24562 /bin/sh /usr/sbin/mwan3rtmon
25285 /bin/sh /usr/sbin/mwan3track modem_1_1_2 wwan0 online 100.112.70.76 4.2.2.4 8.8.8.8 208.67.222.222 208.67.220.220
Here is my /etc/config/mwan3
config globals 'globals'
	option enabled '0'
	option mmx_mask '0x3F00'
config interface 'wan'
	option family 'ipv4'
	option reliability '1'
	option count '1'
	option timeout '2'
	option down '3'
	option httping_ssl '0'
	option track_method 'ping'
	option up '4'
	option interval '10'
	option enabled '1'
	list track_ip '1.1.1.1'
	list track_ip '8.8.8.8'
	list track_ip '208.67.222.222'
	list track_ip '208.67.220.220'
config interface 'wwan'
	option count '1'
	option timeout '2'
	option interval '5'
	option down '3'
	option up '8'
	option enabled '0'
config interface 'tethering'
	option count '1'
	option timeout '2'
	option interval '5'
	option down '3'
	option up '8'
	option enabled '0'
config member 'wan_only'
	option interface 'wan'
	option weight '3'
	option metric '1'
config member 'wwan_only'
	option interface 'wwan'
	option weight '3'
	option metric '3'
config member 'tethering_only'
	option interface 'tethering'
	option weight '3'
	option metric '4'
config member 'wan_balance'
	option metric '1'
	option weight '3'
config member 'wwan_balance'
	option metric '1'
	option weight '3'
config member 'tethering_balance'
	option metric '1'
	option weight '3'
config policy 'default_poli'
	option last_resort 'default'
	list use_member 'wan_only'
	list use_member 'modem_1_1_2_only'
	list use_member 'wwan_only'
	list use_member 'tethering_only'
config rule 'default_rule'
	option dest_ip '0.0.0.0/0'
	option use_policy 'default_poli'
config interface 'wan6'
	option family 'ipv6'
	option count '1'
	option timeout '2'
	option down '3'
	option enabled '0'
	option up '4'
	list track_ip '2001:4860:4860::8844'
	list track_ip '2001:4860:4860::8888'
	list track_ip '2620:0:ccd::2'
	list track_ip '2620:0:ccc::2'
config interface 'wwan6'
	option count '1'
	option timeout '2'
	option interval '5'
	option down '3'
	option up '8'
	option enabled '0'
config interface 'tethering6'
	option count '1'
	option timeout '2'
	option interval '5'
	option down '3'
	option up '8'
	option enabled '0'
config member 'wan6_only'
	option interface 'wan6'
	option weight '3'
	option metric '1'
config member 'wwan6_only'
	option interface 'wwan6'
	option weight '3'
	option metric '3'
config member 'tethering6_only'
	option interface 'tethering6'
	option weight '3'
	option metric '4'
config member 'wan6_balance'
	option metric '1'
	option weight '3'
config member 'wwan6_balance'
	option metric '1'
	option weight '3'
config member 'tethering6_balance'
	option metric '1'
	option weight '3'
config policy 'default_poli_v6'
	list use_member 'wan6_only'
	list use_member 'modem_1_1_2_6_only'
	list use_member 'wwan6_only'
	list use_member 'tethering6_only'
config rule 'default_rule_v6'
	option dest_ip '::/0'
	option use_policy 'default_poli_v6'
config interface 'modem_1_1_2'
	option count '1'
	option timeout '2'
	option interval '5'
	option down '3'
	option up '4'
	list track_ip '4.2.2.4'
	option enabled '0'
config member 'modem_1_1_2_only'
	option interface 'modem_1_1_2'
	option weight '3'
	option metric '2'
config member 'modem_1_1_2_balance'
	option metric '1'
	option weight '3'
config interface 'modem_1_1_2_6'
	option count '1'
	option timeout '2'
	option interval '5'
	option down '3'
	option enabled '0'
	option up '4'
config member 'modem_1_1_2_6_only'
	option interface 'modem_1_1_2_6'
	option weight '3'
	option metric '2'
config member 'modem_1_1_2_6_balance'
	option metric '1'
	option weight '3'
Desired behavior: If I disable monitoring of LTE (or any interface) in the GUI, then mwan3 should not monitor that interface.
While mwan3 still monitors wwan0 even when configured not to do so in the GUI, I think I've solved some of my trouble by configuring much less aggressive monitoring. This seems to be close enough to "assume wwan0 is always connected" which is what I wanted by disabling wwan0 in the GUI.
	option count '1'
	option timeout '2'
	option enabled '1'
	option up '2'
	option down '10'
	option interval '60'
Although ps can still see that mwan3 has a process that monitors the modem interface, but it actually stopped track (ping) the modem interface.
You can capture the modem interface package by tcpdump, to check if there is not ICMP packages.
