First off, thanks for your firmware being able to get the USB800 working right out of the box. Its working flawlessly with no drop outs! Using it on an GL-AR150 with beta 3.100.
At&t tends to push all connections to LTE Band 2 in my area, it gets pretty slow at times. Any way to send AT commands to the USB800? When connected to a PC I can send the following but I don’t understand the hex coding to specify specific bands. Novatel info is really scarce out there.
AT$NWBAND?
$NWBAND: 6c00000
AT$NWBAND=?
$NWBAND: bit definitions
$NWBAND: 00 CDMA2000 Band Class 0, A-System
$NWBAND: 01 CDMA2000 Band Class 0, B-System
$NWBAND: 02 CDMA2000 Band Class 1, all blocks
$NWBAND: 03 CDMA2000 Band Class 2 place holder
$NWBAND: 04 CDMA2000 Band Class 3, A-System
$NWBAND: 05 CDMA2000 Band Class 4, all blocks
$NWBAND: 06 CDMA2000 Band Class 5, all blocks
$NWBAND: 07 GSM DCS band
$NWBAND: 08 GSM Extended GSM (E-GSM) band
$NWBAND: 09 GSM Primary GSM (P-GSM) band
$NWBAND: 10 CDMA2000 Band Class 6
$NWBAND: 11 CDMA2000 Band Class 7
$NWBAND: 12 CDMA2000 Band Class 8
$NWBAND: 13 CDMA2000 Band Class 9
$NWBAND: 14 CDMA2000 Band Class 10
$NWBAND: 15 CDMA2000 Band Class 11
$NWBAND: 16 GSM 450 band
$NWBAND: 17 GSM 480 band
$NWBAND: 18 GSM 750 band
$NWBAND: 19 GSM 850 band
$NWBAND: 20 GSM Band
$NWBAND: 21 GSM PCS band
$NWBAND: 22 WCDMA I IMT 2000 band
$NWBAND: 23 WCDMA II PCS band
$NWBAND: 24 WCDMA III 1700 band
$NWBAND: 25 WCDMA IV 1700 band
$NWBAND: 26 WCDMA V US850 band
$NWBAND: 27 WCDMA VI JAPAN 800 band
$NWBAND: 28 Reserved for BC12/BC14
$NWBAND: 29 Reserved for BC12/BC14
$NWBAND: 30 Reserved
$NWBAND: 31 Reserved
AT$NWBAND2=?
$NWBAND2: bit definitions
$NWBAND2: 00 WLAN US 2400 band
$NWBAND2: 01 WLAN ETSI 2400 band
$NWBAND2: 02 WLAN FRANCE 2400 band
$NWBAND2: 03 WLAN SPAIN 2400 band
$NWBAND2: 04 WLAN JAPAN 2400 band
$NWBAND2: 05 WLAN US 2400 band
$NWBAND2: 06 WLAN EUROPE 5000 band
$NWBAND2: 07 WLAN FRANCE 5000 band
$NWBAND2: 08 WLAN SPAIN 5000 band
$NWBAND2: 09 WLAN JAPAN 5000 band
$NWBAND2: 10 Reserved
$NWBAND2: 11 Reserved
$NWBAND2: 12 Reserved
$NWBAND2: 13 Reserved
$NWBAND2: 14 Reserved
$NWBAND2: 15 Reserved
$NWBAND2: 16 WCDMA EUROPE 2600 band
$NWBAND2: 17 WCDMA EUROPE & JAPAN 900 band
$NWBAND2: 18 WCDMA JAPAN 1700 band
$NWBAND2: 19 Reserved for WLAN
$NWBAND2: 20 Reserved for WLAN
$NWBAND2: 21 Reserved for WLAN
$NWBAND2: 22 Reserved for WLAN
$NWBAND2: 23 Reserved for WLAN
$NWBAND2: 24 Band Class 16
$NWBAND2: 25 Reserved
$NWBAND2: 26 Reserved
$NWBAND2: 27 Reserved
$NWBAND2: 28 Reserved
$NWBAND2: 29 Reserved
$NWBAND2: 30 Persistent value from NV
$NWBAND2: 31 Reserved
