Success removes shadowsocks and install shadowsocksR Pro on mifi.
So it would be used normally both youku and youtube.
download ipk from there http://182.150.7.197:10000/v743/ar71xx/generic-16m/ipk/base/
你好,这个ssr的文件可以发一份吗?我找了好多都用不了MT300v2
他的服务器上面有。MT300N-V2用这个,http://182.150.7.197:10000/v743/ramips/mt7620-16m/ipk/base/luci-app-shadowsocksr-pro_2.0-19_all.ipk
Hi @kyson-lok,
Which version should GL-AR750 use?
Regards,
AR750 is ar71xx target, you can download from http://182.150.7.197:10000/v743/ar71xx/generic-16m/ipk/base/
Download links don’t work.
this zip include four files.
Archive.zip (260.8 KB)
you can install ipks like this:
opkg install pdnsd-alt_1.2.9b-par_mips_24kc.ipk
opkg install shadowsocksr-libev-alt_2.5.1-2_mips_24kc.ipk
opkg install ipset-lists_20181104-1_mips_24kc.ipk
opkg install luci-app-shadowsocksr-pro_2.0-20_all.ipk
Hello, how to install an external ipk from mifi (openwrt interface) ? i couldn’t find the access to add a local ipk. Many thx
Can work with v2ray?
no , i use wireguard.
finally installed, but couldn’t work with subscription link, didn’t update the nodes either ssr nor v2ray
Hi @kysonlok01,
I have gl brume MV1000. Which version should I use?
Thanks.
Hi @kysonlok01,
Which version should GL-MV1000W use?
Regards,
v2ray need latest application:luci-app-ssr-plus.
qq2439155747,xianyu:FreeRoute
hi Freeroute,
I have a GL-MIFI but luci-app-ssr-plus isnt available in the plugins.
is there any other way to install shadowsocksR plus on my device?
thanks
