Installing Podkop on the GL-MT3000
I'm trying to install Podkop Установка – Podkop (based on sing-box), but the installation fails due to the absence of the following packages:
sing-box
kmod-nft-tproxy
Commands:
opkg install sing-box
opkg install kmod-nft-tproxy
Both return:
“Failed to install package.”
As I understand it, the problem is that I have an old version of OpenWRT (21.02-SNAPSHOT), but the OpenWRT version from gli.inet has been updated to the latest version, 4.8.1.
What do you recommend I do:
wait for an update from gli.inet
install a clean OpenWRT
or are there clients like Podkop that are just as simple as Podkop?
P.S. I’m from Russia and I’m using a translator, so the translation might not be accurate
There is an OP24 version available for the MT3000, and we have already tested the Podkop installation locally on this version — everything appeared to work properly.
So you may want to try upgrading to this version and test again.
Installation log
root@GL-MT3000:~# sh <(wget -O - https://raw.githubusercontent.com/itdoginfo/podkop/refs/heads/main/install.sh)
Downloading 'https://raw.githubusercontent.com/itdoginfo/podkop/refs/heads/main/install.sh'
Connecting to 185.199.109.133:443
Writing to stdout
-                    100% |*******************************| 11152   0:00:00 ETA
Download completed (11152 bytes)
Router model: GL.iNet GL-MT3000
Downloading https://fw.gl-inet.com/releases/v24.x/24.10.4/mediatek/filogic/Packages.gz
Updated list of available packages in /var/opkg-lists/core
Downloading https://downloads.openwrt.org/releases/24.10.4/packages/aarch64_cortex-a53/base/Packages.gz
Updated list of available packages in /var/opkg-lists/base
Downloading https://downloads.openwrt.org/releases/24.10.4/packages/aarch64_cortex-a53/luci/Packages.gz
Updated list of available packages in /var/opkg-lists/luci
Downloading https://downloads.openwrt.org/releases/24.10.4/packages/aarch64_cortex-a53/packages/Packages.gz
Updated list of available packages in /var/opkg-lists/packages
Downloading https://downloads.openwrt.org/releases/24.10.4/packages/aarch64_cortex-a53/routing/Packages.gz
Updated list of available packages in /var/opkg-lists/routing
Downloading https://downloads.openwrt.org/releases/24.10.4/packages/aarch64_cortex-a53/telephony/Packages.gz
Updated list of available packages in /var/opkg-lists/telephony
Updating database.
Database update completed.
Installing podkop...
Download luci-app-podkop-v0.7.17-r1-all.ipk (count 1)...
luci-app-podkop-v0.7.17-r1-all.ipk successfully downloaded
Download luci-i18n-podkop-ru-0.7.17.ipk (count 1)...
luci-i18n-podkop-ru-0.7.17.ipk successfully downloaded
Download podkop-v0.7.17-r1-all.ipk (count 1)...
Installing podkop-v0.7.17-r1-all.ipk...
Installing podkop (v0.7.17-r1) to root...
Installing sing-box (1.12.22-r1) to root...
Downloading https://downloads.openwrt.org/releases/24.10.4/packages/aarch64_cortex-a53/packages/sing-box_1.12.22-r1_aarch64_cortex-a53.ipk
Installing jq (1.8.1-r1) to root...
Downloading https://downloads.openwrt.org/releases/24.10.4/packages/aarch64_cortex-a53/packages/jq_1.8.1-r1_aarch64_cortex-a53.ipk
Installing coreutils-base64 (9.7-r1) to root...
Downloading https://downloads.openwrt.org/releases/24.10.4/packages/aarch64_cortex-a53/packages/coreutils-base64_9.7-r1_aarch64_cortex-a53.ipk
Configuring sing-box.
Configuring jq.
Configuring coreutils-base64.
Configuring podkop.
Start podkop
service_triggers start
Updating database.
Installing luci-app-podkop-v0.7.17-r1-all.ipk...
Installing luci-app-podkop (v0.7.17-r1) to root...
Configuring luci-app-podkop.
Updating database.
Русский язык интерфейса ставим? y/n (Install the Russian interface language?)
n
Download link:
Upgrade guide:
