I own an E750V2 (Mudi V2) and have been using the load balancing feature so I can get enough bandwidth to work while I’m traveling.
One big thing I’m trying to figure out is some sort of intelligent load balancing. Here’s a few scenarios I’ve run into:
- In one place I’m at the Wi-Fi isn’t stable and the speeds are normally 30mbps, but every 5 minutes or so the drop to nearly zero for about 30-45 seconds. I’m using repeater and a SIM card that’s getting a stable 16mbps. If I load balance for the ideal, I get a solid 40-45mbps, but when the WiFi drops down, I’m getting like 5mbps since it’s still trying to mainly prioritize the WiFi.
If I prioritize the load balancing to be more even, it levels out the low points more, and I get like 10mbps, but at the peaks I’m only getting 30mbps.
Note: I know this is a wacky scenario, but I don’t have any control over it and need something stable to work.
- When temporarily connecting to a different slow wifi over repeater and also using the cellular, I now have to redo the load balancing to prioritize the cellular more. I sometimes work from another location that has quite slow WiFi (5-10 mbps due to heavy congestion).
Basically I’m looking for a solution that can more intelligently and on the fly do the load balancing. Minimally a button that would test the various connection and load balance automatically for when moving to a different setup (and you can fine tune manually). But even better, if it could intelligently spread the load based on what each source could handle at any given moment.
