(My English is bad, I got some translation help)
I have set up a network to cover a 100m distance between two houses, and for this reason, I’ve placed a router at the midpoint. The configuration is as follows: An ONT fiber internet modem is connected to my main router, a GL.iNet GL-MT6000 model. From there, a 50m Cat6 cable runs to a GL-SFT1200, which is strategically placed to not only bridge the connection but also to provide outdoor coverage for the garden area. Another 50m Cat6 cable connects the GL-SFT1200 to a GL-AX1800.
The system generally operates without issues for about 3 to 5 days. However, I then start experiencing connectivity drops about 3 to 4 times a day. Restarting the GL-SFT1200 router at the resolves the issue temporarily each time.
I chose the GL-SFT1200 model for its compact size as I cannot accommodate a larger router in the space available. What could be causing this intermittent connectivity problem?
Are these two houses connected to the same power-grid? If not, you can get huge problems with currents flowing through the shield of your Cat.6-cable.
Better use a fiber connection.
Yesterday, I connected my old DSL (TP-Link Archer VR2100) modem to try it. There has been no problem since yesterday. I will try it for 1 week. But there is a problem, big routers are very ugly and they are left outside. I’m thinking of buying GL.iNet GL-MT3000.
Let’s say I had no disconnection for a week and I bought GL.iNet GL-MT3000, I’m not sure if I will have the same problem.
Is there a guide, what exactly should I do?
I marked DHCP Ignore interface. I did firewall like this: option flow_offloading ‘0’
option flow_offloading_hw ‘0’
I turned on WAN, but it doesn’t show any internet connection on the interface, but the internet is working. What can I do to make it show in the interface? Did I do the steps correctly?
If everything is meant to be on the same network, the MT6000 should be the gateway handling the DHCP, both SFT1200 and AX1800 should be set as Dumb AP, Lan only ports, DHCP disabled and no Firewall.
The MT6000 should be assigning the Static IP for SFT1200 and AX1800.
Sorry for the late reply but you have given very little information on how your network is setup so I’m having to assume.
Because it’s a router, and it tries to connect by WAN. If you use the LAN as input, the default route does not fit - I would assume. So you need to modify it.
