my router model is GL-AX1800
network topology is as follows:
within about 30 seconds or sooner of connecting the quest to the 5ghz, internet is lost on the AX1800's network. if i connect to 2.4ghz its fine, i can connect my phone to the 5ghz and its fine
i need 5ghz for airlink, its the only reason i connect the quest to the wifi
running
ping google.com on a few different devices reveals that the AX1800 itself and all devices under it lose internet, but a device connected directly to the WAN AP 2.4ghz is fine
AX1800's web interface reports that the WAN 2.4ghz is connected but internet not available
intra-network communication remains stable and healthy, i.e. quest can receive airlink from pc, but no internet
edit: forgot to mention, this is a new issue as of a couple weeks ago, and ive tried switching to unstable firmware with no change
So you mean the 2.4G Wireless WAN is still connected but Internet is broken?
Can you get the log after the problem happens?
just reproduced the issue to get logs
Thu Jul 4 18:43:35 2024 daemon.info hostapd: wlan1: STA 80:f3:ef:5d:80:41 IEEE 802.11: authenticated
Thu Jul 4 18:43:35 2024 daemon.info hostapd: wlan1: STA 80:f3:ef:5d:80:41 IEEE 802.11: associated (aid 1)
Thu Jul 4 18:43:35 2024 daemon.notice hostapd: wlan1: AP-STA-CONNECTED 80:f3:ef:5d:80:41 0 0
Thu Jul 4 18:43:35 2024 daemon.info hostapd: wlan1: STA 80:f3:ef:5d:80:41 RADIUS: starting accounting session 6C01FE6BD540DA42
Thu Jul 4 18:43:35 2024 daemon.info hostapd: wlan1: STA 80:f3:ef:5d:80:41 WPA: pairwise key handshake completed (RSN)
Thu Jul 4 18:43:35 2024 daemon.info dnsmasq-dhcp[5677]: DHCPREQUEST(br-lan) 192.168.8.134 80:f3:ef:5d:80:41
Thu Jul 4 18:43:35 2024 daemon.info dnsmasq-dhcp[5677]: DHCPACK(br-lan) 192.168.8.134 80:f3:ef:5d:80:41
Thu Jul 4 18:44:46 2024 authpriv.info dropbear[17496]: Child connection from 192.168.8.113:50606
Thu Jul 4 18:44:50 2024 authpriv.notice dropbear[17496]: Password auth succeeded for 'root' from 192.168.8.113:50606
Thu Jul 4 18:49:24 2024 daemon.info avahi-daemon[5097]: Registering new address record for fdee:6f3c:61c1:1:557a:e43a:411d:c9a9 on sta1.*.
Thu Jul 4 18:49:25 2024 daemon.info avahi-daemon[5097]: Withdrawing address record for fdee:6f3c:61c1:1:e0a2:6a99:1695:8b0f on sta1.
Thu Jul 4 18:58:58 2024 daemon.info hostapd: wlan1: STA 80:f3:ef:5d:80:41 WPA: group key handshake completed (RSN)
Thu Jul 4 18:59:11 2024 daemon.info hostapd: wlan0: STA d2:16:3b:9f:bf:ed WPA: group key handshake completed (RSN)
Thu Jul 4 18:59:15 2024 daemon.notice netifd: wwan (8610): udhcpc: sending renew to 192.168.4.1
Thu Jul 4 18:59:15 2024 daemon.notice netifd: wwan (8610): udhcpc: lease of 192.168.4.168 obtained, lease time 14400
Thu Jul 4 19:03:00 2024 user.notice AdGuardHome[7223]: 2024/07/04 23:03:00.407450 [error] dnsproxy: 9.9.9.9:53: response received over udp: "exchanging with 9.9.9.9:53 over udp: read udp 192.168.4.168:38801->9.9.9.9:53: i/o timeout"
Thu Jul 4 19:03:00 2024 user.notice AdGuardHome[7223]: 2024/07/04 23:03:00.407595 [error] dnsproxy: upstream 9.9.9.9:53 failed to exchange ;rr3---sn-hp57kndz.googlevideo.com. IN A in 20.002697376s: exchanging with 9.9.9.9:53 over udp: read udp 192.168.4.168:38801->9.9.9.9:53: i/o timeout
Thu Jul 4 19:05:37 2024 daemon.err gl-repeater[3008]: (repeater-portal.lua:335) detect portal fail: connect "17.253.13.142 80" fail: timeout
Thu Jul 4 19:06:42 2024 daemon.err gl-repeater[3008]: (repeater-portal.lua:335) detect portal fail: connect "17.253.13.137 80" fail: timeout
Thu Jul 4 19:07:20 2024 daemon.err gl-repeater[3008]: (repeater-portal.lua:335) detect portal fail: connect "17.253.13.143 80" fail: timeout
Thu Jul 4 19:08:27 2024 daemon.err gl-repeater[3008]: (repeater-portal.lua:335) detect portal fail: timeout
Thu Jul 4 19:09:13 2024 daemon.err gl-repeater[3008]: (repeater-portal.lua:335) detect portal fail: connect "17.253.13.140 80" fail: timeout
Thu Jul 4 19:10:04 2024 daemon.err gl-repeater[3008]: (repeater-portal.lua:335) detect portal fail: connect "17.253.13.143 80" fail: timeout
Thu Jul 4 19:10:34 2024 daemon.notice hostapd: wlan1: AP-STA-DISCONNECTED 80:f3:ef:5d:80:41 0 0
Thu Jul 4 19:10:59 2024 daemon.err gl-repeater[3008]: (repeater-portal.lua:335) detect portal fail: connect "17.253.13.140 80" fail: timeout
Thu Jul 4 19:11:02 2024 user.notice AdGuardHome[7223]: 2024/07/04 23:11:02.584953 [error] dnsproxy: 8.8.8.8:53: response received over udp: "exchanging with 8.8.8.8:53 over udp: read udp 192.168.4.168:54914->8.8.8.8:53: i/o timeout"
Thu Jul 4 19:11:02 2024 user.notice AdGuardHome[7223]: 2024/07/04 23:11:02.585103 [error] dnsproxy: upstream 8.8.8.8:53 failed to exchange ;gateway.discord.gg. IN AAAA in 20.001838747s: exchanging with 8.8.8.8:53 over udp: read udp 192.168.4.168:54914->8.8.8.8:53: i/o timeout
Thu Jul 4 19:11:29 2024 authpriv.info dropbear[17496]: Exit (root) from <192.168.8.113:50606>: Disconnect received
sequence of events is as follows:
ssh to router and ran ping google.com to monitor the connection (and mark the beginning of the test in the log)
played an offline vr game for a little while
got off vr and waited for connection to re-establish
disconnected ssh
it took longer than before for internet to drop this time but it did eventually
bruce
July 5, 2024, 1:55am
4
Could you please re-capture the situation one more time, as this syslog cannot find key info about the repeater connectivity.
Have you tried to up/downgrade the firmware without (no check) the 'Keep Setting'?
Have you tried repeat the upstream 5GHz? LAN works ok, WAN
upgrading to unstable branch firmware did not resolve the issue, upstream router does not support 5ghz and ethernet is not feasible
repeated test:
Thu Jul 4 22:07:56 2024 authpriv.info dropbear[9672]: Child connection from 192.168.8.113:52930
Thu Jul 4 22:08:02 2024 authpriv.notice dropbear[9672]: Password auth succeeded for 'root' from 192.168.8.113:52930
Thu Jul 4 22:08:40 2024 daemon.info hostapd: wlan1: STA 80:f3:ef:5d:80:41 IEEE 802.11: authenticated
Thu Jul 4 22:08:40 2024 daemon.info hostapd: wlan1: STA 80:f3:ef:5d:80:41 IEEE 802.11: associated (aid 2)
Thu Jul 4 22:08:40 2024 daemon.notice hostapd: wlan1: AP-STA-CONNECTED 80:f3:ef:5d:80:41 0 0
Thu Jul 4 22:08:40 2024 daemon.info hostapd: wlan1: STA 80:f3:ef:5d:80:41 RADIUS: starting accounting session 3AEA3D1FDB42ED66
Thu Jul 4 22:08:40 2024 daemon.info hostapd: wlan1: STA 80:f3:ef:5d:80:41 WPA: pairwise key handshake completed (RSN)
Thu Jul 4 22:08:40 2024 daemon.info dnsmasq-dhcp[5677]: DHCPREQUEST(br-lan) 192.168.8.134 80:f3:ef:5d:80:41
Thu Jul 4 22:08:40 2024 daemon.info dnsmasq-dhcp[5677]: DHCPACK(br-lan) 192.168.8.134 80:f3:ef:5d:80:41
Thu Jul 4 22:12:50 2024 daemon.err gl-repeater[3008]: (repeater-portal.lua:335) detect portal fail: resolve "captive.apple.com" fail: recv from "209.18.47.61:53" fail: timeout
Thu Jul 4 22:12:57 2024 user.notice AdGuardHome[7223]: 2024/07/05 02:12:57.791806 [error] dnsproxy: 9.9.9.9:53: response received over udp: "exchanging with 9.9.9.9:53 over udp: read udp 192.168.4.168:60699->9.9.9.9:53: i/o timeout"
Thu Jul 4 22:12:57 2024 user.notice AdGuardHome[7223]: 2024/07/05 02:12:57.791809 [error] dnsproxy: 8.8.8.8:53: response received over udp: "exchanging with 8.8.8.8:53 over udp: read udp 192.168.4.168:36542->8.8.8.8:53: i/o timeout"
Thu Jul 4 22:12:57 2024 user.notice AdGuardHome[7223]: 2024/07/05 02:12:57.792083 [error] dnsproxy: upstream 8.8.8.8:53 failed to exchange ;rr2---sn-hp57kn6r.googlevideo.com. IN AAAA in 20.002551451s: exchanging with 8.8.8.8:53 over udp: read udp 192.168.4.168:36542->8.8.8.8:53: i/o timeout
Thu Jul 4 22:12:57 2024 user.notice AdGuardHome[7223]: 2024/07/05 02:12:57.791976 [error] dnsproxy: upstream 9.9.9.9:53 failed to exchange ;rr2---sn-hp57kn6r.googlevideo.com. IN A in 20.001820572s: exchanging with 9.9.9.9:53 over udp: read udp 192.168.4.168:60699->9.9.9.9:53: i/o timeout
Thu Jul 4 22:12:58 2024 user.notice AdGuardHome[7223]: 2024/07/05 02:12:58.832141 [error] dnsproxy: 9.9.9.9:53: response received over udp: "exchanging with 9.9.9.9:53 over udp: read udp 192.168.4.168:56485->9.9.9.9:53: i/o timeout"
Thu Jul 4 22:12:58 2024 user.notice AdGuardHome[7223]: 2024/07/05 02:12:58.832280 [error] dnsproxy: upstream 9.9.9.9:53 failed to exchange ;rr2---sn-hp57kn6r.googlevideo.com. IN A in 20.00213745s: exchanging with 9.9.9.9:53 over udp: read udp 192.168.4.168:56485->9.9.9.9:53: i/o timeout
Thu Jul 4 22:12:58 2024 user.notice AdGuardHome[7223]: 2024/07/05 02:12:58.847324 [error] dnsproxy: 8.8.8.8:53: response received over udp: "exchanging with 8.8.8.8:53 over udp: read udp 192.168.4.168:58329->8.8.8.8:53: i/o timeout"
Thu Jul 4 22:12:58 2024 user.notice AdGuardHome[7223]: 2024/07/05 02:12:58.847482 [error] dnsproxy: upstream 8.8.8.8:53 failed to exchange ;rr2---sn-hp57kn6r.googlevideo.com. IN AAAA in 20.001780574s: exchanging with 8.8.8.8:53 over udp: read udp 192.168.4.168:58329->8.8.8.8:53: i/o timeout
Thu Jul 4 22:13:00 2024 user.notice AdGuardHome[7223]: 2024/07/05 02:13:00.843644 [error] dnsproxy: 9.9.9.9:53: response received over udp: "exchanging with 9.9.9.9:53 over udp: read udp 192.168.4.168:59342->9.9.9.9:53: i/o timeout"
Thu Jul 4 22:13:00 2024 user.notice AdGuardHome[7223]: 2024/07/05 02:13:00.843653 [error] dnsproxy: 9.9.9.9:53: response received over udp: "exchanging with 9.9.9.9:53 over udp: read udp 192.168.4.168:39718->9.9.9.9:53: i/o timeout"
Thu Jul 4 22:13:00 2024 user.notice AdGuardHome[7223]: 2024/07/05 02:13:00.843896 [error] dnsproxy: upstream 9.9.9.9:53 failed to exchange ;rr2---sn-hp57kn6r.googlevideo.com. IN A in 20.002263787s: exchanging with 9.9.9.9:53 over udp: read udp 192.168.4.168:39718->9.9.9.9:53: i/o timeout
Thu Jul 4 22:13:00 2024 user.notice AdGuardHome[7223]: 2024/07/05 02:13:00.843805 [error] dnsproxy: upstream 9.9.9.9:53 failed to exchange ;rr2---sn-hp57kn6r.googlevideo.com. IN A in 20.002244661s: exchanging with 9.9.9.9:53 over udp: read udp 192.168.4.168:59342->9.9.9.9:53: i/o timeout
Thu Jul 4 22:13:00 2024 user.notice AdGuardHome[7223]: 2024/07/05 02:13:00.859410 [error] dnsproxy: 9.9.9.9:53: response received over udp: "exchanging with 9.9.9.9:53 over udp: read udp 192.168.4.168:39860->9.9.9.9:53: i/o timeout"
Thu Jul 4 22:13:00 2024 user.notice AdGuardHome[7223]: 2024/07/05 02:13:00.859409 [error] dnsproxy: 8.8.8.8:53: response received over udp: "exchanging with 8.8.8.8:53 over udp: read udp 192.168.4.168:43415->8.8.8.8:53: i/o timeout"
Thu Jul 4 22:13:00 2024 user.notice AdGuardHome[7223]: 2024/07/05 02:13:00.859574 [error] dnsproxy: upstream 9.9.9.9:53 failed to exchange ;rr2---sn-hp57kn6r.googlevideo.com. IN AAAA in 20.00172645s: exchanging with 9.9.9.9:53 over udp: read udp 192.168.4.168:39860->9.9.9.9:53: i/o timeout
(lots of adguard spam, i cut it out to make the char limit)
Thu Jul 4 22:14:32 2024 user.notice AdGuardHome[7223]: 2024/07/05 02:14:32.810009 [error] dnsproxy: upstream 8.8.8.8:53 failed to exchange ;graph.oculus.com. IN A in 20.001786263s: exchanging with 8.8.8.8:53 over udp: read udp 192.168.4.168:52676->8.8.8.8:53: i/o timeout
Thu Jul 4 22:14:33 2024 user.notice AdGuardHome[7223]: 2024/07/05 02:14:33.016955 [error] dnsproxy: 9.9.9.9:53: response received over udp: "exchanging with 9.9.9.9:53 over udp: read udp 192.168.4.168:35738->9.9.9.9:53: i/o timeout"
Thu Jul 4 22:14:33 2024 user.notice AdGuardHome[7223]: 2024/07/05 02:14:33.017086 [error] dnsproxy: upstream 9.9.9.9:53 failed to exchange ;edge-mqtt.facebook.com. IN AAAA in 20.00173968s: exchanging with 9.9.9.9:53 over udp: read udp 192.168.4.168:35738->9.9.9.9:53: i/o timeout
Thu Jul 4 22:14:33 2024 user.notice AdGuardHome[7223]: 2024/07/05 02:14:33.017906 [error] dnsproxy: 9.9.9.9:53: response received over udp: "exchanging with 9.9.9.9:53 over udp: read udp 192.168.4.168:40043->9.9.9.9:53: i/o timeout"
Thu Jul 4 22:14:33 2024 user.notice AdGuardHome[7223]: 2024/07/05 02:14:33.017983 [error] dnsproxy: upstream 9.9.9.9:53 failed to exchange ;edge-mqtt.facebook.com. IN A in 20.002666601s: exchanging with 9.9.9.9:53 over udp: read udp 192.168.4.168:40043->9.9.9.9:53: i/o timeout
Thu Jul 4 22:14:34 2024 daemon.err gl-repeater[3008]: (repeater-portal.lua:335) detect portal fail: connect "17.253.13.134 80" fail: timeout
Thu Jul 4 22:14:36 2024 user.notice AdGuardHome[7223]: 2024/07/05 02:14:36.922327 [error] dnsproxy: 8.8.8.8:53: response received over udp: "exchanging with 8.8.8.8:53 over udp: read udp 192.168.4.168:42196->8.8.8.8:53: i/o timeout"
Thu Jul 4 22:14:36 2024 user.notice AdGuardHome[7223]: 2024/07/05 02:14:36.922469 [error] dnsproxy: upstream 8.8.8.8:53 failed to exchange ;meta.graph.meta.com. IN A in 20.00175206s: exchanging with 8.8.8.8:53 over udp: read udp 192.168.4.168:42196->8.8.8.8:53: i/o timeout
Thu Jul 4 22:14:36 2024 user.notice AdGuardHome[7223]: 2024/07/05 02:14:36.922327 [error] dnsproxy: 8.8.8.8:53: response received over udp: "exchanging with 8.8.8.8:53 over udp: read udp 192.168.4.168:34593->8.8.8.8:53: i/o timeout"
Thu Jul 4 22:14:36 2024 user.notice AdGuardHome[7223]: 2024/07/05 02:14:36.922567 [error] dnsproxy: upstream 8.8.8.8:53 failed to exchange ;meta.graph.meta.com. IN AAAA in 20.00172606s: exchanging with 8.8.8.8:53 over udp: read udp 192.168.4.168:34593->8.8.8.8:53: i/o timeout
Thu Jul 4 22:14:37 2024 user.notice AdGuardHome[7223]: 2024/07/05 02:14:37.615529 [error] dnsproxy: 8.8.8.8:53: response received over udp: "exchanging with 8.8.8.8:53 over udp: read udp 192.168.4.168:43686->8.8.8.8:53: i/o timeout"
Thu Jul 4 22:14:37 2024 user.notice AdGuardHome[7223]: 2024/07/05 02:14:37.615691 [error] dnsproxy: upstream 8.8.8.8:53 failed to exchange ;gateway.discord.gg. IN AAAA in 20.001906019s: exchanging with 8.8.8.8:53 over udp: read udp 192.168.4.168:43686->8.8.8.8:53: i/o timeout
Thu Jul 4 22:14:37 2024 user.notice AdGuardHome[7223]: 2024/07/05 02:14:37.615529 [error] dnsproxy: 8.8.8.8:53: response received over udp: "exchanging with 8.8.8.8:53 over udp: read udp 192.168.4.168:33874->8.8.8.8:53: i/o timeout"
Thu Jul 4 22:14:37 2024 user.notice AdGuardHome[7223]: 2024/07/05 02:14:37.615973 [error] dnsproxy: upstream 8.8.8.8:53 failed to exchange ;gateway.discord.gg. IN A in 20.002111229s: exchanging with 8.8.8.8:53 over udp: read udp 192.168.4.168:33874->8.8.8.8:53: i/o timeout
Thu Jul 4 22:14:50 2024 authpriv.info dropbear[9672]: Exit (root) from <192.168.8.113:52930>: Disconnect received
these repeater ones look most relevant
root@GL-AX1800:~# logread -e repeater
Thu Jul 4 20:43:09 2024 daemon.err gl-repeater[3008]: (repeater-portal.lua:335) detect portal fail: connect "17.253.13.135 80" fail: timeout
Thu Jul 4 21:00:29 2024 daemon.err gl-repeater[3008]: (repeater-portal.lua:335) detect portal fail: connect "17.253.13.141 80" fail: timeout
Thu Jul 4 22:13:55 2024 daemon.err gl-repeater[3008]: (repeater-portal.lua:335) detect portal fail: resolve "captive.apple.com" fail: recv from "209.18.47.61:53" fail: timeout
bruce
July 5, 2024, 3:37am
7
May I know if the WAN-AP which AXT1800 repeat it have required to login the portal page?
what? i cant tell what youre trying to ask
i dont know anything about the WAN AP, i dont have access to it. i assume its just some generic ISP router
bruce
July 5, 2024, 4:04am
9
OK.
And one more thing confirm if you already use the attatched power suppiler for AX1800?
yes, im using the power supply it came with
LupusE
July 7, 2024, 7:02pm
12
I am not a VR expert, but from your description it sounds like the Quest2 provides a DHCP service that is confusing the whole LAN.
Is it possible to deactivate the LAN management. (DHCP) at the Quest2?
This could make sense at a ad-hoc setup to let the devices around know how to communicate. But not in infrastructure mode when another router is present. I can imagine it is some kind of IPv6 voodoo, that the GL-iNet router is not supporting, now. So the Quest2 thinks there is no router and takes the management role.
Very speculative. But better to start than nothing.
oh good, this sounds much more helpful
i dont think i'd be able to find much settings about dhcp in the quest, but if its related to ipv6 i could disable that in the router. that might actually make sense because i enabled ipv6 only a month or two ago, i dont remember having this issue until more recently but i could be wrong about the timeline
i'll try that later today when i have a chance
wow, disabling ipv6 fixed it, never would have guessed. thanks so much!
disabling ipv6 was not the solution, it came back but i've just been dealing with it
but now its progressed to the point that i lose internet connection whenever the quest 2 is connected, no matter what
i can work around it by using my phone with usb tethering to the router, but its not a very good solution due to the data being metered and the connection being lower quality
bruce
July 3, 2025, 7:35am
16
Have you tried to upgrade the AX1800 to v4.8.0 firmware?
